can you put an obs 7.3 in a 99-02?
1 reading
2.4K views 6 replies 5 participants last post by  alberta 7.3
i have a 96 powerstroke and was wondering if the engine is the same as the newer ones? i heard the newer ones had junk rods. but can i take my 96 motor and bolt it into a 99 and everything hooks up?
#2 ·
As far as I know you can use most of the hard parts but many accesories need switched. THe junk rods I believe are in the 01-03 engines
#4 ·
the zf6 will bolt up in place of the zf5 and but the autos are computer controlled so i dont belive they will interchange i may be wrong u should have called me i would have told u this :poke: you changing your block into a new truck?
#5 ·
the early 99 is a bassturd child of the two 7.3 it has some obs parts and some sd parts
#6 ·
btw powdered rods arent junk. just not strong for high HP mods.
#7 ·
Physically, the 99+ block is thicker. Everything will bolt up to the OBS block, but it's a lot of parts swappin'
