Cold A/C heater hose valve???
4.2K views 11 replies 6 participants last post by  zpd307
Ok, I am going to do this mod... Nothing fancy, I am just going to put a manual valve in-line with the hose. It's Florida, and I will probably leave it blocked off 8 months out of the year. And it is not that big of an inconvenience to me to just pop the hood and turn the valve lol.
My queston: Which of the two hoses coming out of the firewall should I put the valve in??
What size is the hose??
Thanks:icon_ford:
#4 ·
Get a bypass type valve and use both heater hoses. IIRC it's 5/8" hose. I picked up a vacuum operated bypass valve at carquest that was listed for a chrysler product of some sort. I could have ran the vac. line into the cab to operate the valve, but I just put it under hood. I used a lawnmower gas shut off valve to operate the vacuum. Make sense? Anywho.. it made my AC colder! :)
#5 ·
your truck should all ready have the vacuum bypass valve. it actuates on max a/c.
#12 ·
interesting, i will have to check mine then.....
#8 ·
could you take some pics of this, very interested with the 100 degree temps we will be having for next couple months:thumb::thumb:
#10 ·
Can you post a link? I've never heard of this, but I am very interested after the first full day working in 90+% humidity and 100 deg heat index for the year today.
Anyone know which trucks had this with the max a/c on like was mentioned before, was it just some? Mine is an early 99. I'm very much interested in getting this done asap.
