I have an 07 350 with just under 200,000mi. I had a head gasket leak and installed studs hoping to keep this from happening again. When I torqued them down I snapped one off in the back drivers side. (I did this all with the cab raised slightly) I destroyed the threads getting it out and got a new threaded insert installed. The rest of the project went well... Now that it's running I have some grey/white smoke out the tail pipe at low speeds and when I punch it it turns black. Some times it seems like it misses. I'm not sure if this is an injector issue or if this is a result of getting some shavings in the cylinder that was closest to the hole that I had to rethread. I did my best to tape it off and keep stuff out but I can't help but think that maybe that could be part of the problem. I hope I'm just paranoid. Any help would be appreciated. Thanks guys/gals.
