Last Friday night I was driving down the highway and I was going to pass someone and as I did I got on the throttle a little bit about 3000 or so RPM to pass the guy and as I did I hear a loud KA-BANG! I didn't loose any speed as well as I didn't see any smoke or anything like that but hear a loud rushing of air from the turbo plus a loss of power. I limped it off the next exit to investigate and I pop the hood seeing the intercooler popped off. Not knowing the failure rate and thinking due to the fact I removed it that day to investigate the EGR delete for possible leaks that it must have popped off because it was too loose so I tightened her up and went down the road only for it to do it again minutes later. At that point I tightened again and by the time I got to my destination you could hear air leaking slightly so I popped the hoods to see it slipping off again. I would like to know a proper way to fix this, do I replace the silicone boot? do I replace the clamps? (If I do, can I use regular hose clamps or must I use the kind of clamps they have on there?) How tight must I make them? and what kind of tool should I use? (a regular hand wrench or a torque wrench?)
Thank you
I need feedback on this one please.
Thank you
