First off, I'm an idiot.
I have a 2004 F250 and I've been going through trying to figure out what the previous owner had that he removed. I saw that the VGT had two wires spliced (one on each) and even though I don't care for the smoke deal, I wanted to try it since I thought that was what it was for. There was already a switch to these cheap lights all hooked up, so I connected the wires from the existing switch to the existing spliced wires. Turbo on, turbo off. No smoke. I figured it doesn't work then it was not meant to be.
I removed the wires from the spliced ends...no turbo, no high end power. I put the wires back on, turbo spools, tons of bark, kind of makes a loud stutter sound, no real high end power.
Additional info - I'm in Boise and it's 10 deg. while I'm working on it, after a while of working on it, I give up, and try and start it. Glow plugs stay on a long time and when it starts, RPMs jump to 2000 and the engine surges.
Also, SCT x4 tuner with the 60/50 tow tune. No codes. Took it to Autozone and got no codes from them either.
Any help would be greatly appreciated.
Thanks,
Daniel
Thanks,
Daniel
