What is this stain under my truck?
1 reading
1K views 3 replies 4 participants last post by  JustinOOO9
I have a 03 f250 7.3 with 328k on it, and I have noticed this stain under my truck when it rains. It sort of looks like how a leaking head would look. Coolant and oil are fine, dipstick shows no milky nor does the cap. I don't loose oil or coolant surprisingly. New water pump, and new oil change recently (about 2 months ago) and all fluids looked fine, nothing concerning. Coolant is still gold, oil is still golden. Any ideas what this stain could be?
#2 ·
Look under your truck. These ol gals are notorious for leaking off the back of the engine. Look at the bottom of the bell housing. See if you have the famous 7.3 drip off of it. If its been wet the water "could" mix with the drip and make the chocolate milkshake looking stain.
Sent from my SM-G955U using Tapatalk
#4 ·
at 328k can garuntee some fuel line sleeves and some o rings on the fuel bowl are leaking diesel. That diesel rolls down towards the back mixing with whatever oil and drip down the back of the engine. bunch of people always think its a rear main leak 99.99999% its not. its turbo pedestal o rings, hpop lines, and or leaky fuel bowl o rings most commonly fuel bowl drain valve and fuel pressure regulator.
spray some simple green and water and let it soak for 20 min then do it again a couple of times and stuff some old white t shirts around the fuel bowl, hpop lines etc. start the truck and you'll see which shirt gets wet faster etc. im betting combo of oil and fuel from fuel bowl o ring etc.
