I have a whining noise coming from the motor. It sounds just like a power steering pump low on fluid, but that is not the problem. You can hear the noise at idle and it gets louder with more fuel if your moving or not. Any suggestions??
1) turbo turbine damaged, or bad bearing 2) Alternator bearing 3) powersteering/hydro boost pump is dying! Mines weak....wines sitting still, slow turning, or on the brakes hard at a light ....check it all out...spray ur alt down with some silicone spray, see if the sound changes...just my .02
Sorry to hijack your thread but Im having the issue with my 00 7.3L... spent 280.00 replacing the p/s pump...I posted earlier then I saw its in the 6.0 forum... I'm hoping nothing super serious... is there any way to see if its a pulley or the Turbo? As it seems to be rpm related, and when I replaced the p.s. pump one part of the dual pitch noise went away... it sounds like a supercharger whine is the best way to describe it...
Any ideas
my did it for 2 years then idler pulley let go at 1 o clock when you look from the front $ 35 pulley and $54 for the belt + 200$ for the tow
Related Threads
Ford Powerstroke Diesel Forum
posts
5.5M
members
295K
Since
2005
