LONG post but i'm trying to be as detailed as possible.
i've been dealing with this strange noise for about 2 weeks.
driving at speed 35-60mph and the road turns to the left, as i'm going through the turn I hear some strange rough, growling,whirling, grinding vibration/noise type thing.
some time it does it all of the time, sometimes it wont do it at all?
and it also seems to do it more while there is a little load on the engine, I can go around a corner giving it anywhere from 1/4-1/2 throttle(engine load on my torque pro is around 50) and it will do it, but the next turn i'll let off the gas and it wont make a peep. but other times it will?? (it is hard to tell where it is coming from because of the engine.......
I thought it was the unit-bearings but lifting the truck the wheel spins nice no friction in it. and I pulled the calipers too.
it had new ball-joints, tierods, draglink, shocks put on late 2013.
brakes are good too new pads and rotors put on early 2013. and the inside and outside surfaces look great.
I had someone turn the wheel back and forth for about 15 min while i sat under the truck looking of any free play with wheels on and off the ground(NONE)
looked at all the sway bars and bushings and they are original, but I cant see where there any sign of play, (worn paint, or movement while yanking on them)
i've bounced on the bumpers at all four corners,
I cant get the truck to make a peep while stopped...
all the parts put on the truck were motorcraft parts put on at the dealer(per the oasis report)
could it be the LS in the rearend? that is about the only think I havent physically checked. any other truck I've ever had when the LS went bad it bade more of a chattering noise.
anyhelp would be great, thank you in advance
